LiE's Diet and Training Thread
OK so today I did workout C which I thoroughly enjoyed. The aim was for lighter weights and more explosive. I increased the weights on bench press progressively to see how the explosiveness translated for each set. I'd say 90 was about right, 100 was a little bit to much like a normal set, just a bit faster.
Bench Press
BAR, 60x10, 80x10, 90x10, 100x10, 100x10, 80x12
Pull Ups
10, 9, 8
CGBP
60x10, 80x10, 80x8
Seated Cable Rows
42.5x10, 57.5x10 x3
TRX Inverted Rows
10, 10, 10
Land Mines
20x10, 25x10, 25x8
Lying Leg Raises
10, 10, 8
20 minutes leg stretching
I'll have to have a play. For some reason my shoulders come in to play too much.
Are your shoulder blades pinned back as well?
You'd be surprised what will cause you to be fatigued. I did only ten minutes of circuits yesterday but my early sets of squats were absolute carp. I almost failed today :(, twas weird :).
Yea it's most certainly down to the change of program mid week. Trained my core on Tuesday and Thursday then Squatted on Friday.
So feeling pretty fresh after the weekend. Looking forward to workout A tonight. Heavy deads and some explosive benching :)
Could have probably done another 200 triple but needed to keep my energy up for the rest of the workout. Mixed it up at the end and hit the core hard with some slow dragon flag negs. Wanted to do seated cable rows but it wasn't possible so did some lat pull downs.
Workout A
Deads
80x7, 100x6, 130x5, 160x3, 200x3, 200x3
Bench Press - Light/Explosive
bar, 60x10, 90x11, 95x10, 95x9
Dips - Volume
BWx15 x3
Lat Pull Downs
50x10, 70x10, 80x8, 80x7
TRX Inverted Rows - 1 sec pause at top
8, 8, 8
Land Mines
25x8 x3
Leg Raises
8
Slow Dragon Flag Negatives
3
15 minutes band stretching.
Here's a video of set 2 of my 200kg triple.
Not too bad, speed seems good and fatigue isn't too bad.
Yes my gym has installed red lights... it's like Amsterdam in there.
Thanks :) I need to watch the head. I was really trying to focus on upper back tightness and "arse down, chest up" today.
I think your head position is so fundamental to your spinal mechanics that it's going to require a hefty deload and lots of time to fix.
Do you do any mobility work for your thoracic spine?
My head position is improved when I actively think about it, at least I think it is.
Not perfect, but I was trying which I normally don't do on the very heavy stuff. I really should.
Only thing I do for thoracic spine is occasionally do some thoracic extensions on the foam roller.
