Virgin Media Discussion Thread
i thought it's after their upgraded hardware the area you are in.
because some people as already got it. also afew as already got 120/12
http://forums.overclockers.co.uk/showpost.php?p=22008240&postcount=4472
not sure mate, the engineer that did my upgrade said that the upload speeds won't change until they have finished the current download speed upgrades.
Just checked on VM site and you are correct.
http://community.virginmedia.com/t5...our-customers-broadband-speeds/m-p/958421#M62
The upload speeds are changing at the same time as the download speeds... I know, because I've had my upgrade:
Woo... got my upgrade :)
Today hasn't had any slow downs either apparently (I wasn't in but the other half has been)... so maybe these hardware upgrades they're doing with the rollout are improving the oversubscribed areas a bit :)
I think if you request an upgrade before you are automatically upgraded then your upload speeds remain the same until the rest of your area are all done. (automatically)
I've been upgraded to 60Mb from 10Mb after discussion with Virgin's retentions dept.
Downloading the 1GB test file from here (http://www.thinkbroadband.com/download.html) is pretty consistent for me.
No flash on the browser on this server and I'm not installing it :p
From memory, the speedtest.net result was around 62Mb/s Down and 2.96Mb/s up.
Very pleased apart from the shocking saga I had prior to the SuperHub arriving!
The upgrades for upload are coming later because it (apparently) requires an update to the Superhub to fix upstream line bonding, which is being trialled as we speak.
Just stuck the superhub on modem mode and added an Asus RT-N66U... and I'm rather impressed... it's given me a massive improvement in latencies - greatly noticeable when browsing the web & a good few ms off in BF3 :)
Doesn't really matter what router you have as long as it's not bargain basement, it doesn't take much to beat the superhub :p
my connection as got bad by the looks of it.
ether most people in my area as upgraded to 100Mb or theres a issue.
but im still getting good speed and ping
how do we know TBB is giving a true reading
