Man of Honour
- 29 Mar 2003
- Blurton
Has anybody got a Topeak MTX Beamrack and what do you think?
Yep I've got one. I used it for my 400 mile ride through France on my carbon bike (no eyelits, which I assume is the same reason you're looking at it). Was very very good. Carried a lot of stuff for the week with the side frame and panniers too and even survived a crash.
Considering it's only got one point of contact with the bike it was extremely stable.
I *think* I've got the E-Type - http://www.topeak.com/products/Racks/MTXBeamRackE-Type - but I'd have to check. They're all the same, the only difference is the kink in the bar to make sure it sits above your back wheel.
I've then got this bag: http://www.topeak.com/products/Bags/MTXTrunkBagEXP plus the side guards.
No idea about it fitting on certain bikes, I just took mine into Evans and fitted it there and then to check.
Is it best to swap to a triple groupset or change the rear cogs if your struggling on steep hills?
This pedal and shoe combo is quite a popular pair for beginners. It's what I'm still using a year+ on.
http://www.chainreactioncycles.com/Models.aspx?ModelID=3760
http://www.chainreactioncycles.com/Models.aspx?ModelID=55382
£80.99 all in. Easy enough to replace the pedals as long as you've got a large enough hex key and remember that the left pedal is reverse threaded (ie unscrew clockwise).
Have you by any chance got a picture of your setup?
[DOD]Asprilla;22045767 said:You can get the M520s for £20. Still double sided but more plastic and less metal. Yet to have a pair fail on me after 4 years.
I have Shimano A530 pedals on a couple of my bikes, so that I can use normal shoes when I want to ride to the shop or something. As for the shoes, I went for a pair of Shimano M087 instead of proper road shoes, as they're a lot easier to walk in, and it's easier to get the wide sizes.How trippy are those shoes? I was looking at ones with recessed cleat spaces so it was easier to walk on?
I'm half tempted to get those double sided ones you can use with normal shoes, anyone tried those?
Nope, not my bag of chips. Are you doing it?Anyone doing the Dunwich Dynamo?
I'm half tempted to get those single sided ones you can use with normal shoes, anyone tried those?
Yep, planning to do that one fixed gear (but I have got a new 16T freewheel at homeNope, not my bag of chips. Are you doing it?
