Just completed act 3 inferno on my barb finally
. Had to skip a couple of rares but killed all the bosses with 5 neph so it wasn't too bad.
Havnt seen this thread for like 2 days and its already 30 pages more lol.
Gratz, I've only go through first boss on act 3, what gear do you use?
Can you add me @ PhoenixUK#2160 .
Also, to any barbarians that got to inferno and have doubts - gear makes a massive difference.
I could do act1 quite easily then I thought its ridiculous when I got to act2.
After getting few new items I could already nearly afk in act1 ( literally, can stand in group of mobs for half minute and they wont kill me then I can probably 1 hit them by pressing revenge once ). Could run it easily with dual wield or 2h and offensive passives/skills.
Then I've somehow managed to get through act 2 with, was hard and took a lot of effort by my gear still wasnt that good. Got to belial and couldn't kill him for a while until I got some more new gear then it became extremely easy.
Act 3 was again totally new level of difficulty, first I got ****** by first normal mobs outside of the gate but day later after changing few bits I've got through to first boss and slowly progressing through altho I might do some more farming first.
*** IMPORTANT ***
1. I can do act 2 super easily with dual wield and no shield + 1 or 2 offensive passives as well. Things hardly have any time to do any damage to me as they die in a hit or two and my weapons arent even that great. I can run through act3 normal mobs and some champ packs depending on abilities with dual wield as well and no shield.
2. When you upgrade your gear do not do same mistake as I did when I bought gear without a perfect stat ( ie, high all res, physical res, str but 0 vit ). It's better to save your cash and buy the perfect piece ( they start at 700-800k to 1,5-2mil ) and slowly upgrade 1 item at a time rather than buying full set of half good items for 200-600k as not only they will allow you to progress only a little bit further then you will have to change it again BUT also prices drop extremely fast and the piece that you bought for 500k might only resale for 150k in 3-4days time when you want to change it.
I've bought a lot **** gear that I've only realised now I have to change anyways. Anything that hasnt got both very high str/vit ( sometimes crit % , atk speed can be taken instead of str ) along with high all res + fire res or physical res is useless and you will need to swap it by the end of act2.
