YOUR BASKET
1 x Gigabyte GA-E350N-USB3 AMD Hudson M1 DDR3 Mini ITX Motherboard £81.98
1 x Thermaltake Element Q mini-ITX HTPC Case - 220W Power Supply £56.99
1 x Sandisk Ultra SSD 60GB 2.5" SATA-2 Solid State Hard Drive - (SDSSDH-060G-G25) £49.99
1 x Crucial 4GB (1x4GB) DDR3 PC3-10600C9 1333MHz 204-Pin SODIMM Module (CT51264BC1339) £16.99
1 x OcUK Professional 2.5" to 3.5" SSD Adaptor Plate - Black £4.99
Total : £222.95 (includes shipping : £10.00).
This is an example of a budget HTPC. The E-351 is a motherboard and APU all in one. It is quite capable of 1080p playback and is used in several of the Revo models.
The SSD will help with quick booting and quiet operation as it has no moving parts.
The only thing it won't do it play back 3D MLC files natively, so if 3D is something you may consider then you will need the next model up which is the E-451. (An extra £20-£30)
You can easily install openELEC on this with XBMC - they has AMD APU specific installs as well which will help: OpenELEC Fusion Builds
This should leave you with some extra ££ left over for a 2TB HDD to put in your PC which you can put your media on - or get an BluRay disk drive to play Blu Rays from.
Just get a little PCI 5.1/7.1 card, most come with optical out.
