- 23 Dec 2009
- RG8 9
It can, as I am using one.
Ok, I will probably get the one thats black, with white legs,
If OcUK does not prove me otherwise
In a year, I might report back if I buy it![]()
YAY!!! A lefty like me
I will buy it, it looks good,
how long have you had it?
The ikea stuff will be OK. I have had mine for 2 years now and not a mark on it.
Well.... except the marks that the wood effect has.![]()
Looks like a desk to me.It can, as I am using one.
Cmon dude..
what if it turns to sponge when his gear is on there?
Then he can soak up his liquid when he has spillages.
True, and there will be shock resistance, good for earth quakes?
If there is an earthquake you can just jump on top and you will be kept safe from the shakes.
I'm definetly buying this![]()
It fits perfect, same dimentions as the desk I was gonna build (but 15cm shorter length wise)
It's thicker that the custom desk, always nice![]()
Is there something like this, but wider so I can put my case on top with plenty of room for the rest of my stuff?
For you sir I recommend kitchen bench with ikea custom legs. I would say around £40.00 + depends on the type of custom legs / kitchen bench.
In my old house when I used to rent I purchased a custom kitchen sparkling bench top + ikea legs. Worked perfectly. (£60.00) as legs were £9.00 each (extendable ones).
