I just uploaded it to photobucket straight away after taking the pic Mate. I'm not sure if photobucket automatically resizes pics or displays them as originally taken?
cheers - so you didn't adjust any resizing settings on Photobucket?
22 degrees here in a rather swelteringly hot room
p.s Skillmister![]()
The S4 chip is more than capable for running games as well as every day stuff infact it's the best chip out there at the moment and Samsung knows it, that's why they've bought the rest of Qualcomm's stash for the S3. That in itself speaks volumes as Samsung rather use the S4 chip rather than their own Exynos chip!
I thought it was pretty good! Downsized to my screen (1920x1080) it's nice.
@Lighters
I've removed loads more bloat
how? did you just disable the processes you don't want running or have you actually removed them?
He has done it just by using the built in feature of ICS
Go to settings>apps>click on app you want to disable>top right disable
It simply deactivates the app, will still take space up on the mobile but will no longer show in the app drawer, use any resources etc.
i was just curious to see if there was a way of actually getting rid of (as in for good [without rooting]) the ****.
i've disabled loads now and all the other apps are filling up memory, all in all, success![]()
What kind of stuff have you disabled then? Don't think i've done any on mine so far
Rang up T-mobile to get my PAC code and the guy tried to confuse me buy spouting out lots of specs for the Samsung galaxy s advance saying it was faster and better then the HTC One S. Also tried to get me to get the Xperia U but I mentioned the memory isn't expandable and he said that was the first he'd heard of it.
