- 22 Apr 2011
- Nottingham
Just got a TP link 500mb kit, Installed it after BT engy finished installing sky fibre and all is working well.
The plugs are on the same floor, 1 room apart yet the signal is 40-60%, Is there any way I can get it higher?
Data rate is about 220mb, Is that acceptable for 500mb plugs?
They're getting quite warm/hot, is this normal?
cheers
cheers
