Light Flow is the best... I have it configured with Go SMS, WhatsApp, GMail and Missed Calls![]()
I take it you just took the plunge and bought it? Seems a waste just to get an LED for Handcent when it does all the other ones I want for free
I take it you just took the plunge and bought it? Seems a waste just to get an LED for Handcent when it does all the other ones I want for free![]()
I am now running Siyah Kernel and underclocked to 1.2GHz and undervolted by 50mV. I have run a stress test for 30 minutes and its all good![]()
Just tried Lightflow Free too. Can confirm that it doesn't work with HandcentNot paying because I know CM will bring different LED indicator colours.
Under-clocking doesn't necessarily mean you'll get much better battery life. In fact, in certain scenarios it may well be worse because your CPU will spend less time in deep sleep because the clock speed is lower. Food for thought![]()
This doesn't make sense? you are removing the upper cpu limit from 1.4 to 1.2, that wont effect deep sleep will it?
I was in exactly the same situation, I had my S2 setup just how I liked it, I'm not a phone power user and just like having a nice phone.
The camera is miles better on the S3, mainly because of no shutter lag so you won't ever miss a photo while it's saving or not letting you take a photo with is a massive bonus.
I'm selling my S2 to a friend with 2 batteries, an extended battery, a charging dock, an office power pack and 2 cases (just to show you all the extra bits and pieces I had for mine).
Battery on the S3 for me so far appears to be about 10%-20% better than the extended S2 battery.
Get it![]()
Indeed, I've been using my S3 since Friday and love it, also had a S2 but I had to flash the O2 ROM on there because I'm selling it and it feels so small.
Couldnt use that device again![]()
FWIW, Nandroid backups are 2GB+ on this monster!
Great thing though is that with CWM app you can choose to restore just the kernel setup if you often try different kernels, or modem or just the data partition etc. Makes restoration a breeze, saves time.
Why use handcent anyway, the built in sms is enough on the s3 - You can change colours of the backgrounds.
Why use SMS
WhatsApp is where it's at!
Why does it not make sense, lower clock speed less voltage = more battery.
It wouldn't affect deep sleep at all.
But there is a different school of thought, where it should run at the highest clock speed possible to finish task quicker. So the device can go back to sleep (race to idle).
Why use SMS
Or Viber
