never seen that error message before. Maybe worth checking if the Video memory can address the full 2GB (don't know what tools are available to do that)
Try -if not already done- to set the field multi Display/ mixed-GPU acceleration to to single display performance mode.
I got this error whilst running Virtu MVP...Is he running the same?
Yep, got MVP on but turned it off as that was a result from a quick google and it still happened when disabled. Shouldn't have to be fully uninstalled surely?
Odd how i use MVP on an ASrock z77 ex6 with a 2500k and it doesnt crash for me..
but you have a 7970?
Maybe different version? I have no idea tbh and found uninstalling it was not a loss. Maybe he should check his mobo manafacturer for an update? I know my was fine untill I installed the newer NVIDIA drivers.
field multi display? He only has one monitor and i assume this setting, probably part of Nvidia software, is going to be set to single monitor by default, especially if he only has one.
More details on where i can change it would be cool.
I do indeed have a 7970 so 1GB more Vram in theory but if mvp is the problem then its would be odd if the gpu makes more of a difference? Mine suffered from memory leak...If on a map too long, it would kick in and I suspect if yours was faulty, it would eventually kick in for you also.
I will get him to check version of mvp.
It might be a duff card, that is one of the errors my GTX580 'OC edition' would throw up before I found out that it was common problem among pre-overclocked cards and increased the core volts, upping the volts or setting the card back to reference clocks completely fixed all my BF3 problems at the time.
Is it a reference clocked card or custom overclocked by KFA? if the latter I would try underclocking slightly see if it helps...
This is the card: http://www.overclockers.co.uk/showproduct.php?prodid=GX-014-KF&groupid=701&catid=1914&subcat=2255
So yes, it is factory overclocked. Would he need to set the clocks to exactly what the reference clocks should be to test if the factory overclock is what is doing it?
