So tempted to get this phone as my 2 year iPhone 4 contract has now come to an end. Bet there must be a lot of iPhone 4 early adopters like me thinking along the same lines.
My only concern about going down the Android route is that I'm so used to the simplicity of iTunes syncing for things like firmware updates, podcasts, app management etc. Can someone here who has come from an iPhone comment on how they found the transition?
Try instore or a friends. The whole design of Android means it doesn't require an iTunes like app but you can use one if you really want (it would be Kies or Double Sync I guess here), the bigger day to day differences are the homescreen and customisation rather than the items you mentioned to be honest. In terms of the things you mentioned:
Firmware updates - Done via Kies (Software from Samsung) on an SGS3 or OTA. Simple as hell, your phone will even tell you when it's available if you enable the option.
Podcasts - either direct download with an app or transfer from pc with drop and drag. Mine sync as soon as I get back to wifi every day, this is simpler than Firmware even.
App management - go into the store ("Play") and click the app then click uninstall. Done. Feeling flash? Install over the air through play.google.com. Store takes all major credit and debit cards
