Hi,
I have been given a Sinnis Matrix II (peugeot Sum-Up) scooter that is 2 years old and done just over 5k miles.
The problem with it is that some chavs tried to steal it. They borked the ignition lock, then cut the loom and tried to hot wire it. This didn't work so they left it alone. The owner then didn't use it for about 7months and it is been left out in the elements.
So today I took most of it apart and it looks to be in quite good condition. The front disc is rusty, the exhaust is a bit manky and the rear shocks are shocking. Apart from this, I would like to fire it up to see if it still works!
Check the fuel is not stale, oil is there, battery is charged - all ok
But I have no ignition. I have drilled out the lock so I can now turn the key. I have checked it is making contact with the switches it needs to and it does. I charged the battery up to 12v, and I think I have wired it up correctly.
No matter what I try I can't get any thing to light up, or turn over. I have not had a ped before so am clueless to the starting procedure. Do you have to press this and twist that to get it to fire up (electric starter)?
The lock switch on the dash is set to off. Should I at least get lights and stuff when the ignition is on, a bit like in a car?
All fuses are ok, but I am yet to use a multimeter to see if anything is drawing a current, and the battery is still ok.
Any ideas?
Ta.
Any ideas?
Ta.
