This might affect a few people on here
http://rog.asus.com/forum/showthread.php?17588-Nvidia-s-answer-to-x79-and-PCI-e-3.0&
The GTX 690 uses pci-e3 on the R4E.
From what I've read it's only 670/680's thats affected
Users of systems running Core i7 processors in the LGA2011 package and X79 chipset motherboards will find that their GeForce GTX 680 will not run at PCI-Express 3.0 x16 mode, using launch drivers. This is because NVIDIA decided against implementing Gen 3.0 support for the new GPU on X79/SNB-E systems, at the very last moment. Pre-launch drivers, including the driver that ships on discs with the graphics cards, and review drivers (which cannot be distributed), will let the GPU run at Gen 3.0 mode on some X79/SNB-E systems, however the post-launch stable drivers (such as GeForce 301.10 WHQL), won't.
The specifications page of GeForce GTX 680 on GeForce.com has been updated to mention this:
GeForce GTX 680 supports PCI Express 3.0. The Intel X79/SNB-E PCI Express 2.0 platform is only currently supported up to 5GT/s (PCIE 2.0) bus speeds even though some motherboard manufacturers have enabled higher 8GT/s speeds.
Sources in the PC motherboard industry we spoke with, confirmed this change. PCI-Express 3.0 x16, for now, might only run on upcoming "Ivy Bridge" Core systems, running on motherboards with PCI-Express 3.0 compliant components. NVIDIA could be working to fix the issue.'
http://www.techpowerup.com/162942/G...-Express-to-Gen-2.0-on-X79-SNB-E-Systems.html
Don't think it much of an issue myself but just thought I would give a heads up.
Thats the bit I find strange. A GTX 690 is 2 GTX 680s on the same card. So what is the problem with running 1 GTX 680 @pci-e3 if 2 on a card have no problem. If you disable sli a gtx 690 turns into a 680.
Another bone of contention that has been laid to rest is the fact the Sandy Bridge-E processors feature PCIe Gen 3 as its controller is 8 GT/s-capable; however, the validation of PCIe Gen 3 capable switching components amongst motherboard manufacturers seem to have started a war of words between two prominent board makers. Hence, Intel has seemingly decided to err on the side of caution and kept mum on their PCIe Gen 3 capabilities as evident in the X79 chipset block diagram.
As seen from the block diagram above, there is still no official word on its support for PCIe Gen 3.0 though motherboard makers have implemented their own compliant switching components on their X79 offerings.
Because it's the PEX8747 PCIe switching hardware chip that handles the PCIe 3.0 data on board for SLi.
what is really galling about this whole thing is that clearly they've tested some motherboards and found some to work and some not but they won't even tell us which ones they've tested
+1 for PCI-E 3.0 on my 690s, at least according to GPU-Z
