- 23 Jun 2004
- Blackburn
Hmm I'd disagree on that one. Id rather bend a bar, than have it start to wiggle loose.
I don't mean loose as in you hit a rock whilst turning and your bars twist out of alignment
I mean the stem shouldn't be clamped so tight that it doesn't move. In the event of a hard crash were you could have bent you bars your stem twists out of alignment thus saving your bars. I'd much rather have to take 10 secs to realign my bars than have to end ride and shell out £50. That said I run a bolted stem
