- 19 Jun 2012
Hi all
I am looking to invest in a new keyboard and mouse but am struggling to find anything that I like as much as my G15 (V1) and MX518
I'm hoping you folks may be able to aid the search
My 518 is on deaths door from the well known cable break problem. This is a cause of much disappointment for me because my last 518 lasted around 5 years, but my current 518 has lasted less than 2
In the last couple of years I have tried an MX1000, a Lachesis, a Storm Sentinel, and a Kone V2 - none of which I can get on with. I'm using my Lachesis as a spare at the moment but oh dear I cant get on with it. I mostly play 1.32 Quake III Arena (Real Q3 not that QL ****!), but also do a lot of SP FPS gaming too. I'm a low sense player and I use a big Steel Series QcK Heavy cloth mat
Is it me or are laser mice just naff for lower sens FPS gaming? I need an optical! I have been a huge fan of the MX-5xx series form factor for many years and have come to rely on the button layout for Q3 (2 on the thumb and the 2 on top behind the scroll wheel). Do I just plump for a G400 and be done with it, or do I try something else and adapt? I used an MS Wheel Mouse Optical before I had my first Mx500, but I simply cant imagine having to remap the 4 weapons I use on the mouse to my keyboard
I have been playing with the same cfg since about 2002 so adapting now will be a headache.
My G15 V1 has been an absolute diamond of a product. Still going strong after 6 years. The WSAD keys are losing their coating though and the LED's are not as bright as they could be but it still works flawlessley. The only problem is I have been ham fisted and broken off the plastic lugs on the wrist rest and rear feet
So its no longer comfortable for gaming on as the keys are angled down towards the rear of the keyboard when it sits flat on the desk. If I could get another I would, but the only available 'new' versions are aparrently not up to the same quality according to what I have read. I can well believe it too, as my current 518 has lasted less than half the time of my previous one. So if the quality of the mice have declined it makes sense that the kyboard quality will have dipped as well.
Budget wise I dont have one really, but if I am going to spend a lot of money, the product needs to match the price in terms of stability, longevity and performance. For instance my G15 has been used most days for 6 years and apart fromn the damage I have caused still works fine. I need reliability, build quality and I need consitency. I dont want to mess around with having to RMA a product thats still at Beta stages and has no right being on the market at all (thats another topic but its an approach both hardware and games developers are taking - whatever happened to releasing something that works out of the box?).
I made the epic mistake of buying a razer Lycosa a couple of years back. Oh dear. Draw a line under that one......Straight back to my G15.
I'm not overly bothered about mechanical vs dome keys because I have got along just fine without mechanical for the last 6 years! BUT the keyboard must have a full QWERTY layout with a full size enter key - I cant be doing with those tiny enter keys! So layout wise the same as a G15 V1. Although I dont use Macros for gaming, I have found the G keys on my G15 very useful for assigning form data for log ins etc (usernames, email address, password etc). Plus I cant see the future so I may get into a game where the G keys are needed. G-Keys wont be a deal breaker but I would prefer the option of programmable keys.
To sumarise:
Mouse Requirements:
Optical preferred (Any DPI as I am not drawn in by useless DPI figures. 6000 DPI? No ta, im not playing on a 72 inch TV!). Would not rule out a laser thats tried and tested at low sens - but so far im struggling to find one.
Durability / build quality
MX-5xx variant button layout preferred (would consider other configurations if the mouse was phenomenal)
Wired preferred, but would not turn away a phenomenal wireless - again needs to be tried and tested
Budget - Any - but i need it to last as my missus aint gonna let me spend again for a few years!
Preferably NOT a razer product
Keyboard Requirements:
Full QWERTY layout with normal sized enter key.
Programmable keys preferred, but not a deal breaker
Backlighting preferred (blue if possible) - but again not a deal breaker.
No preference on mechanical or domed so long as quality is class leading.
good quality feet and wrist rest - I prefer my keyboard to sit at an upward angle and not flat on the desk.
Budget is same as the mouse.
Preferably NOT a Razer Product
So far my short list is pretty boring but I admit I havent kept up with all of the products out there, so there may be things available that I dont know about.
Shortlist so far:
Logitech G400 mouse
Logitech G510 keyboard
REALLY like the look of the Corsair K90 but the corsair forums are full of woe (Some people have had to RMA their keyboard 3 times!) and depending on the pics you find, im unsure about the enter key size.
Any help and advice appreciated, along with actual user experiences of products.
Cheers
Buff
To sumarise:
Mouse Requirements:
Shortlist so far:
Logitech G400 mouse
Cheers
Buff
