Anyone running 'deck'? Iam finding it a good replacement for sbsettings.
Yes Deck I have had since its initial release. Its far better than SBSettings dispite several arguments with people who refuse to try Deck. Looks and operates like an apple element.
Right, I want to jailbreak my 4s, but am I right in thinking that when IOS6 is released, i'll be stuck with my jailbreak for a few months before I can use the "benefits" of IOS6?
I can't get the 'kill all apps' working using deck tho![]()
So I believe but on earier releases of springtomize it never worked for me.Just installed Deck and am in love with it. I disable spotlight anyway as I never use it so have Deck set to come in on the left side when i swipe in from the left onto the screen - brilliant.
Much cleaner than the SBS settings and that always annoyed me how the icons don't line up neatly in notification centre
Jhonny - you can change carrier name in Springtomize rather than use another app to do it (Zepplin)
What is the error that usually comes up? You won't need to unjailbreak it, Chances are if you unjailbreak it, The same error will come up.I am on 5.0.1(Jailbreaked) and I tried to download the 5.1.1 update but whenever I try and install it there is always an error and it doesn't work. Do you need to unjailbreak it before you can update? If so then how do I do it without losing all my pictures, videos, apps etc.
Works fine for me? It won't kill an app if that app is running when you activate deck. It will only kill all apps when activated from home screen
 so am I right in thinking to close all running apps.  You use deck 'kill all apps' on the iPhone homescreen and all apps are removed from the tray?Still can't get this workingso am I right in thinking to close all running apps. You use deck 'kill all apps' on the iPhone homescreen and all apps are removed from the tray?
Does JB unlock your phone?
I'm with o2 and moving to giffgaff next week so need to unlock my handset, I purchased the handset from eBay which was listed under an o2 contract, completed the o2 online form for unlocking but had nothing back as yet so looking at other options in the mean time
