- 7 Feb 2004
What appliances have you bought?
Just pricing them up now.
Probably going for Siemens cookers, microwave, hob, extractor (maybe neff), dishwasher. Miele larder fridge and tall freezer. Beko tumble dryer.
You were doing so well until you mentioned Beko.
Siemens and Bosch are the same thing so save some cash and buy the Bosch.
i cant see where your door is now on this plan, it seems as though you got an american style fridge in front of where it would be?
just had a similar refit done at mine, as mentioned before, put the utility and kitchen on seperate rings,
We don't need that door now since we knocked the wall between the dining room and kitchen down.
I decided not to go with an American style, the freezer part isn't very big, the ice cube makers have a tendency to break and take up a large chunk of space inside. Instead I'm going for a 600mm wide Fridge and 600mm wide freezer bolted together.
Are you not having a door into the ultility room at all then? I would think though its another door to open, with the washing machine/tumble dryer in there a door would help keep the noise shut out from what will become a main living area in the house.
I thought from pictures of current kitchen you have fridge/freezer in the ultility room but new kitchen they'll be in the main area. A door there would be a constant pain when going back and forth to fridge/freezer while cooking a meal, but for storage and washing, I'd put a door there to keep the noise out of the way as much as possible.
Noise was my concern, because the other work looks fab, shame to spoil it with something you can't easily 'plan' in the 3D software, but you can think about it!
Shame to be worrying about hob placement to chat with friends if there's a washer+dryer banging away in the background!
Just a quick update, only a week to go.
We needed to choose the actual pieces of granite for our worktop so went to a granite importers, the place was freakin huge and it was a difficult decision to make.
The guy showing us around was really knowledgeable, explaining about each piece and were they came from. They own the quarries and he regularly visits them.
We were after a light coloured granite with dark tints. We narrowed it down to two, Delicatus and eventually chose one called Bianco Antico.
It's similar to this but each slab has it's own features and tints of other colours, we needed to chose two 'slices'.
You get standard granite like the plain blacks you often see but this is one of the exotics, great, once again the price of the kitchen goes up.
You were doing so well... until the end... You can't get black Granite...
Looks a nice slab of stone and looks like it may actually be granite however. Considering you went to a specialist I assume they could tell you exactly what it was?![]()
