Already been done.
http://www.overclockers.co.uk/productlist.php?groupid=701&catid=14&subid=1894
Not really worth it imo as you just double the chances of component failure and the speed/price/performance ratio just doesn't make sense.
Sorry, I think you misunderstood. I know there are hybrid drives where NAND caches a HDD but in that case it isn't doing away with mechanical storage entirely is it! What I described was a hybrid where rather than a traditional HDD, instead in its place there would be a large amount of cheap NAND (the kind of stuff you can get in USB flash drives) and there would be a smaller amount of say fast Toggle NAND to handle the speedy stuff such as OS, etc. Maybe it's entirely unfeasible but it was just a thought that occured to me.
Drive caching works really well. You can gain about %90 of the performance of an SSD but have 1-2TB of storage space. I used to have a 60GB SSD to cache a 2TB drive and got superb results.
Would it be worth me getting a 64gb sammy for my games array instead of buying a 256gb one and sticking them all on there do you think?
It worked really well for me. Tbh I now have 2 x Samsung 830 drives for my games and I'm thinking of going back to a mechanical drive with a cache drive as the difference in speeds is not that much and not having to move games around all the time is so much better.
64gb drives are such bad value for money now compared to the 128 and 256's though!
256gb would be more than enough for what I play in any one period of time. I currently only have cs:s installed along with l4d2.
1.4TB? You can't seriously play them all at the same time?!![]()
What are you going to do with those lovely new samsungs then :0
If you have mechanical drives in your system as well that will slow down boot times but also people make out SSD drives much better than they are, they have good points but i would never say to anyone there fantastic.
