Program to view Ram.
Under the "Sensors" tab in GPU-Z, there should be "Memory Used", like so:
It doesn't matter how much graphic card memory you have with 2 or 3 cards in xfire,you can only use and access the amount on one single graphic card
I Run bf3 @ 1920x1200.
Says the Memory Dedicated is uses 1927mg I have crossfire, which has 2Gb
I'm i running out of ram?
Cheers :)
Thats memory usage of one card, if you click at the bottom were it says
AMD Radeon HD 6900 Series
then choose the other card, it will show the memory usage of the other card also
does that mean that on my llano system there is no point in me dedicating 2 gb to my intergrated graphics since i have a 2gb 6670?
i swear ive seen my graphics go usage go up to 2.6gb whilst playing battlefield 3
Oh ok..
But i thought it only uses 2G and note 4 in total, as you think you would get having 2 cards..
Is this on the edge then with bf3 ?
Cheers :)
Setting aside pc memory might be different but 99% sure max gpu memory is limited to single card regardless of xfire
Looking at those gpuz screen's its using 300mbs of ram atm,doesn't it store the readings to text? That way you can see how much its used while gaming
Basically any data stored in one card will also be copied to the other cards in crossfire/SLi. So no need to look at the others...
It's crossfire but it's technically not true crossfire. Sort of like hybrid crossfire which AMD calls "Dual graphics". Not sure how the memory will work then... but probably best to set it to 2gb to match your 6670. There are some programs which adds all the memory together such as MSI afterburner, so you need to half this to get the true usage.
And don't just use BF3, it's one of the very few games that actually eats VRAM :p. Most other games won't reach the limit.
So what am i looking at, the Dynamic and not the dedicated?
From what i read it's the Memory Usage (Dedicated) i just tried rfactor. and that only went to 1100. but bf3 near 2000. maybe thats why the game runs **** lol..
I read people say they run out of memory at higher res, mine seems to in bf3 @ 1920x1200 as i have everything maxed out.
Not sure how to set it to 2gb to match my 6950's or add the memory together:)
First i've heard of that :) can tell me if u like ;)
So for bf3, which i play most of. would a 4GB make it a lot smoother?
Cheers :)
yes look at the dynamic,left click dynamic and dedicated tick the show maximum for both,then tick the log file and play bf3,it will then show you the max amount of dynamic vram used in gpu-z and the text log file
keep gpu-z running while you play bf3
Right i did that.
Memory Usage (Dedicated) [MB] highest 2440
Memory Usage (Dynamic) [MB] 263
Surley BF3 isn't only using 263mb? out of 2GB
I'm confussed now, as i hear others say theres using 1.5gb etc IN BF3.
The game must not like crossfire!
Can someone explain this plz :)
Cheers :)
at the risk of sounding very stupid could some one explain dynamic memory and dedicated memory in a multi gpu set up
would dynamic memory be what the main card robs from the second card?
