Hi,
Can someone one let me know if you can multitask on the S3? If so how?
It does it for you. Just hold the home button to switch between apps.
You know that is not real multitasking right? Not like WebOS.
Its still multitasking to me. What does webOS do to make it more "real"?
Keeps the programs in memory, proper multitasking as if on a desktop PC. You can set a website loading in the browser, go do other things for a while and come back to it fully loaded. In android it stores the fact you were using a browser and the url you were at and reloads it when you go back to it - subtle but highly important difference.
SO I am going to try out this Omega v6.0 ROM, I've just done a backup with CWM so after this new ROM is installed I can recover things like messages, contacts etc right?
Edit : Or do I i need to backup with something like Titanium Backup instead?
Well I have now got a backup from both CWM and Titanium, but from what I have read and watched on youtube I don't need to wipe the phone completely anyway because I am still using the standard ICS ROM which came with the phone (although it is rooted)?
Install CWM Recovery with Odin - Get CWM Recovery here
Boot to CWM Recovery using volume up, power button and home key
Backup your device and make sure to keep a copy of the backup to your pc!
Wipe data / factory reset (Not needed if you already have Omega)
Wipe cache
Wipe dalvik cache
Install Omega
Does it do any damage to the battery leave it on charge while the battery is full?
My phone is charging now, and I am about to go to bed, it will be fully charged in the middle of the night but I won't get to unplug it until the morning. Does this do any damage to the battery (like keeping a laptop on charge for too long)?
shouldn't be a problem, the charger should switch off or go in to a trickle charge mode.
