Would probably have jumped at that had I not already bought one heh, ah well I'm loving mine, especially the colour tbh, baked bean for the win.
Cleaned twice this week, once jut a quick wash, the second time a bit more thorough then used autoglym aqua wax, but I think my lack of patience and me knee problem meant I've done a shoddy job. It's amazing the marks you notice the first time you thoroughly clean a car. Mine is -covered- in tar, I tried some tar treatment but I think this must have been on here long term, perhaps time to clay bar? Bit of an amateur really!
So, question. Having never had grooved brakes before, is the time to replace the discs just before the grooves wear out, or is it before/after that? No problem with them, just thought I'd ask while I remembered
I do love the brakes though, they're only green stuff pads and grooved discs so I'm highly tempted to try Brembo HC and ds2500s when they've worn out
Another question is after a hard drive home from work this afternoon, the temperature dial creeped up to about half a notch above middle, whereas from what I've noticed, it doesn't generally move normally. It was fairly warm, and it was a good hard drive. Should I be worried? No sign of problems with coolant, and it didn't't go any higher than that half a notch. Started to cool down after I got into town in pootle mode.
