i dunno what to do then, i aint got millions to spend on the gear clearly required to do act 2 and im tired of farming act one to try and find the 1/2 ilvl 63 items that might just be an uber upgrade for me.
For what it's worth, I can do act 2 with worse stats than you have in pretty much every regard (albeit with a dual-wield build that aims to take advantage of the extra dodge available) so I don't think you should give up hope yet. Those with 1h+shield seem to use life on hit as a crutch to get through the content when armour+resists isn't enough but I think that's only properly viable with higher attack speeds. So you just need to find out what will really work in the context of 2-handers...easier said than done I know. Perhaps gearing and skilling for high spirit regen + high life per spirit spent is the way forward?
