Sorry mate, but what a load of horse manure...
Kai you still using straps? You should drop them.
Dips are my favourite. Did you do CGBP or Dips after bench? I prefer to do dips first then CGBP.
Is he even natural?
Don't see a problem if he's doing a max lift tbh. As long as other grip work is done and not all sets are with straps!
Don't take this particular personal vendetta too seriously, <5 mins for a warm isn't going to cause problems... it isn't necessary though.Yes, I am trying to do the exercises!
The only reason I use the cross trainer is because I thought it gets all parts of the body moving so it looked ideal for the warm up process. I could try a short session on the rower instead?
Very informative post regarding the warm up. Might be worth putting it in the mobility thread?![]()
My thoughts exactly (although I don't hate IFProbably, but still, it's another gimmicky program that won't actually do anything different than sticking to the basics
brb doing a 36 day program then having to either do it again so it's a constant 36 day program(wtf?!) or have to cut or bulk anyway
Carb cycling definitely has it's merits and well worth looking at, but why do it in a 36 day time period, it's a load of ****
Just a marketing ploy for Grenade so people buy there products
Absolute ****, I'd recommend IF over that any day, and that's saying something as I detest IF
).Don't take this particular personal vendetta too seriously, <5 mins for a warm isn't going to cause problems... it isn't necessary though.
I may add to the post and put it in the exercise guide![]()
despite being the heaviest I've ever lifted (67.5kg for all 3 sets) they didn't feel all that heavy but my form was all over the place. I was bracing the core and trying to hump the bar as if my life depended on it but I can still feel that it's not right.By the way Delvis, sorry to nitpick but it's dodgy not dodgey, every time you write that I read it as bogey for some reason :\
