£30 graphics card HELP!
24 Apr 2012
Bridgwater
so i need a new graphics card for my computer nothing fancy just its needs to run hd content and needs to run minecraft with good proformance and it need to be cheap as possible
£30ish will get you something like a second hand Nvidia 9600GT/8800GT/9800GT/250GTS/260GTX, ATi 3850/3870/4850/4870 - any of which will run HD content, minecraft, and plenty of other games just fine.
Yep on a very tight budget buying second hand is a good bet, although from a reputable member's market/place.
u see i going to get a gtx 670 for battlefield and mw3 but getting that in a couple months and i want to upgrade my current athlon hp pc to run minecraft it does like 10 fps because it has ati 1150 or something built in
There's a ATI HD 6570 for £49.99 with a passive cooler. That's what I'd pick if you could stretch to £50.
What spec is your CPU and RAM? Minecraft is fairly intensive...
you'll be fine with a 6450 on a 250W PSU. I've run athlon 64 x2 systems with old GPUs (about 40W) no problem. I even have an old dell system with a 3GHz HTT prescott pentium 4 with a working PSU and a 9800 pro in it. The CPU alone used over 100W!
I had a radeon 4670 for agessss which ran off the PCI lanes power and managed Minecraft on full, 1080p videos etc... Was a great little card for the price and even ran crisis on acceptable settings :P
I doubt you'll stress the card enough for it to draw its max watt output anyway, but be careful just incase, I wouldn't run that stock PSU for too long, upgrade it as soon as you have the chance after you get your GPU, someone here should quote you something nice...
