Suspended
- 17 Oct 2011
- Buckingamshire
I think I'm going to try an 80-90mm one and see if it sits me a bit more upright so I take a little less weight on my hands and wrists.
[DOD]Asprilla;22224398 said:Yup, it's a stunner.
It's also steel rather than Ti.
I'd still kill for it.
Your gear cables look very stretched with the bars at that angle.
why not flip the stem you have? a little more height and a little less reach
[DOD]Asprilla;22223997 said:It's my commuter / winter bike rather than my weekender.
snip
Hi guys. Currently have a GT Aggressor (bought in 2008ish through a cycle to work scheme). Didn't see much use until this year, so got it serviced and have been using every couple of days for the past few months. Slowly building up my distances! However I think I'll be doing road cycling for the forseeable future - can I switch the tyres for something that isn't offroad? It often feels like the tyres are causing a lot of resistance!
Also is there anything else I can (fairly cheaply) change to help with road cycling?
tbh anything you do to it, the frames still going to be heavy etc.
higher pressure in the tyres?
lock out the forks
