Try downclock the boost to around 1150mhz, force constant voltage of 1.175v and see if it crashes again, if not my money is the chip can't handle the boost set by kfa2. Think a similar thing happened with some of the 670 dcuii cards, think there was talk of a vbios update to fix it?
+1
Im not sure what Gibbo has seen on these cards but usually the errors only occur if your card can't render everything correctly at the speeds its set to, this is generally because the clock speed is too high.
the card is simply not stable at the speed it is meant to be stable at, returning it is the best option!
You mean 1200mhz surely?
Heaven fully maxed out should find faults fairly quickly as well (8x AA, extreme tessellation etc..)
[ZiiP]carrot;22245389 said:Nah this isn't a software issue. It's randomly crashing. Lasted 2 hours in battlefield 3 tonight and then a crash. The card is unstable....
