Heres a tip, if you put your CPU in the oven at about 80C for 10 mins the silicon glue should go pretty soft.after that I would suggest a thin softish plastic spatula kind of thing to just lever the IHS off. It's what I plan to do with my 3770k and seems the safest bet of not killing the cpu imo
Or just IBT it for 10 mins, shut down, pull out (burn fingers
), grab sharp utility knife and pray!
Anyway, how big is the correlation between memory speeds and cpu core voltage when ocing to high levels?
Got rather annoyed this morning when I discovered that cpu frequency/voltage was no longer working at previously stable tested settings.
Then it occurred to me on my way into work, that I have been upping the memory speed/timings
Now, I am aware that faster memory will allow higher throughput to the cpu, but didn't really think it would be the the extent I have epxerienced.
When I initially started clocking this chip, I was getting 4.9 stable, with around 1.25V - but I had the Samsung Green on stock, which is a very relaxed 1600 11-11-11-28-2t
Then I needed around 1.26/1.27V. But I think this might be when I started upping the mem speeds to around 1866 with 9-9-9-28-2t.
When I figured out how to get memory past 1866 on the sabertooth, I set it at 2133 11-11-11-2t, but needed to up vcore to around 1.28V.
Then this morning I started failing IBT at 1.28V, and later remembered that I had changed timings to 10-10-10-2t.
I know I have done the whole thign a bit backwards - I was only just telling someone the other day to OC memory where you want it first, as it faster memory could require higher vcore when aiming for high clocks at lowest possible voltage.
So tonight I am going to put the memory back to stock, and see if I can get back to the 1.25V for 4.9GHz. If I can, it means at least that my CPU has not degraded as I was beginning to suspect.
If this is the case, then I just need to decide if I want to sacrifice a bit of cpu speed for memory speed, or vice versa.
