So its carefully wedged in then with the foam you think?
What is holding the second intake fan in place, looks like foam? Been thinking about adding another fan up there myself. Also does the addition of the top two fans cause a noticeable difference for you in terms of temperature?![]()
Would you recommend adding another intake at the front and the two extra at the top then? I'm in the upgrading mood![]()
