Anyone else running leaked JB on the Nexus having WiFi signal issues? I note that someone's produced a fix for the Verizon version but I can't find anything for GSM.
Is this phone a good upgrade over the Desire HD?
Factory Images "nakasi" for Nexus 7
Has anyone noticed with the leaked jellybean that font size is VERY small in some apps and that the NatWest app no longer displays your account info yet displays all the standard app text
This phone for a smidge over £300 or the HTC sensation XE for a tiny bit under?
This by a country mile, as long as you're okay with 16GB storage.
The screen is great, ICS is great, Jelly Bean will be greater, it looks nice, etc.
Which phone have you landed up with Robbo, I forget now?
) as well. I have a Sensation too... (and loads of others
)I'm on the One X at the moment, and I'm getting an S3 next week.
I have the Nexus (which my girlfriend now uses so I can't try JellyBean) as well. I have a Sensation too... (and loads of others
You should put which phone you are using in your sig as we never can tell which one you are using or which on you own.![]()
Perhaps I shall.![]()
You might as well do the same with tablets as I can't tell whether you're still an iPad fanboy.![]()
as you're feeling generous, might as well put you credit card details down there too!![]()
I have the iPad 2 and 3, and I'm getting a Nexus 7.
Still not a fan of the Android tablet apps at the moment though, but they should rapidly improve when everyone gets the Nexus 7.
