What are Grey imports?
Do they come with any warranty ?
hmmmmmm my wireless seems to have buggered up on JB. it did work ok and now it wont connect. or says it is when its not
Would there be any issues using a U.S. purchased Galaxy Nexus in the U.K.?
No problems here( knock wood)
Although am thinking that sometimes it looses sinal much more easy and doesn't connect back easily...
Am still thinking about sgs3... but n7 is on its way and maybe there will be nexus s soon![]()
Does anyone know if Codename Android is still available for this? The download links over on XDA appear to be broken for 4.0.4 and people are saying development has stopped on it.
If so, can anyone recommend a similar ROM? I am looking for one that is similar to ICs, but has extra customisability and battery life.
yeah stock for me from now on, reason i left the lovely s2 for this.
wifi issues fixed after a battery pull
I have run into a bit of a problem and frantic googling doesn't seem to have helped. I installed AOKP milestone 6 and the camera would appear to take photos, but nothing would be stored. I thought it was just and issue with AOKP, but Jelly bean had the same problem. I restored back to a stock image, unrooted and relocked- but the problem still happens with ICS.
Not sure what the next step to take is?
Yes, I cleared the cache and did another full wipe, back to stock and all is well now.![]()
