Road Cycling Essentials
Status
Not open for further replies.
Is it worth worrying about panniers or anything like that, or can I manage with just a rucksack? That may seem a daft question, but I've never ridden with a rucksack before, so don't know how much of a pain in the neck it is. I'll occasionally be taking a laptop to and fro but otherwise it'll just be lunch and clothes...
Yup, backpack is fine. I take clothes and lunch in every day and occasionally heavier items. Top tip is to just leave a pair of work shoes at work though as that reduces the weight and space considerably.
I've got the Deuter Speedlite 20 which is great, and I managed to get it in the sale for £29 at my local Cotswold Outdoors. Can be had at ~£35 from various places. Although I think I'm getting a bit too far ahead now seeing as you don't even have the bike yet :p
I carry a laptop, 2 bags of satsumas, a heavy dlock, change of clothes etc in my backpack on my ride in every day.
not an issue tbh
it's just a normal north face jobbie.
I'd go apex over sora tho.
Hmmm... Lots of options then...
10% work discount on the vouchers
10% code above
10% if I join British Cycling for £24
3% Quidco cashback
Credit card cashback
Versus:
No tax/NIC
Interest free loan
10% free accessories
I'm going to need a spreadsheet.
You'll want to check you can stack the two 10% codes, not sure if that works? Also you won't get credit card cash back if you buy the vouchers, as you are paying in vouchers, not the card, but the quidco cash back should work.
Also take into consideration you will get the bike now, not in a few months time, that's got to be worth something.
I would get a backpack designed for biking, speaking from experience from last summer when I used a cheap old regular sport type backpack it felt as if my back was on fire it was so hot.
been away for a few days guys lol this thread has grown !
to answer the gearing questions I'm running
50/39/30 12-27 currently although i do own both a 11-23 and a 12-25 cassette as well. Going to change to the 12-25 asap then hopefully down to the 11-23 in the next couple of months :)
Hello again...
I realise I'm talking to some fairly hardened cyclists, but it anyone would deign to sponsor me for doing the arduous 25 mile Liverpool to Chester ride on Sunday I'd be very grateful! I'm raising money for a charity called Hopehiv, which supports children and young people affected by the AIDS crisis in sub-Saharan Africa. Between online donations and offline sponsorship I'm only £13 off my target of £500, so any bit of help would be appreciated!
Please go to http://www.justgiving.com/Peter-Urquhart to donate.
Thanks for reading!
hey guys, now this is not going to happen soon, however in the next 6 months or so money depending I am wanting to update my BeOne storm to a carbon fibre. now the problem if it is a problem is that my storm weighs roughly 8kgs, I want a lighter higher specced bike.
so I'll show you what I have,
[img]http://i48.tinypic.com/2rhpe9x.jpg[/img]
now to put it in perspective there have been a number of upgrades from the standard spec
105 hollowtech front crank
ultegra rear sprocket
Vision TriMax Pro Wheels
as well as seat etc
so bike cost me £550 (came with r500 wheels and all tiagra) and I have spent roughly £3-400 on upgrades. (taking the weight from 9.3kg out of the box to about 8kg)
so im looking for an all carbon with at least ultegra or the equivalent campagnolo / sram and a lighter weight, now although not the best wheels in the world the Trimax are 1522 grams so I would be willing to put them on the new bike, hopefully therefore allowing for a higher specced new bike in terms of equipment to which i can transfer the wheels ? or a good specced bike with equivalent or better wheels ?
Now I have my eye on the canyon Ultimate 9.0 Cf with the ultegra triple addition
with a budget of upto £2k what are other options ? or recommendations ?
You probably wont save much money by transferring your old wheels over. Buying a full bike is by far the best value for money and buying just a frame+groupset will often cost around the same as a whole bike.
I would recommend a double or compact crank. With the right cassette, you can get very similar gear ratios to a triple but with less weight and more reliability (i find the shifter on a double a lot easier to setup than a triple)
Also, you'll be able to find a great bike for your budget that will ride great and feel like a massive improvement. However, you wont find anything with a huge weight reduction. The minimum weight limit for pro bikes is 6.5kg, so even the top end bikes are not lighter than that. At £2, you'll probably be looking around 7-7.5kg
Im not adverse to a compact at all in fact it may well be the next best step, the reason i was mentioning the wheels was, in cycling plus there was a really good bike for my budget with cack wheels (r500) so sometimes and only sometimes the wheels i have at the minute would be better and therefore transferable, however on the canyon for example there's not a lot in it however the vision are still 170grams lighter than the mavics. Though as the BeOne would become the winter bike whatever I would take off the new would go on the old if that makes sense.
Canyon and Rose are both worth considering for well specced carbon bikes. Bear in mind they sell for cheaper by cutting out the middle man, but this means you cannot test ride without flying to Germany.
I'm ordering a Rose next week fingers crossed (damn Natwest). I was certain I was going to get a Canyon at first, but they are severely short on stock of XS frames and the 2013 models won't be available until around Jan 2013 apparently. Another advantage of Rose is you can change/reconfigure most bits except for the gruppo.
Didn't he say it was red, but the colour balance in the image was well off?
In other news, Arsey - you mentioned the Xexec vouchers from work for Halfords. I had a look today and it appears to suggest you can use them for anything you want at Halfords, except the Boardman range. Awesome. :rolleyes:
interesting. I'm looking at these two brands for next year. leaning more towards canyon as they seem best value. keep us posted what you go with
Status
