Hi folks, I used to build all my own PCs, but a few years back I sold out and bought a Dell. That experience was about as good as you can imagine, so I'd like to get back in the saddle and self-build again. However I'm very out of touch, and though I'm reading and reading, there's a lot to catch up on, and I would really appreciate some advice on the build. Sorry for the long post - hope it's not "TL;DR" time and some of you can take the time to read it!
Requirements
Mostly I just use the PC for surfing and email, sometimes ripping CDs or transcoding videos. My gaming has all been on the console recently, due to having a crappy Dell, but it would be good to have something that can handle MMOs or RPGs - I don't play FPS or other twitch-fest games.
The PC needs to be quiet, as I sleep and watch TV in the same room, and without bright LEDs lighting up the room.
In the past I used to incrementally upgrade as much as I could, so while I know there's no such thing as "future-proof", I want something that will last a few years with a few upgrades, so while it doesn't need extreme performance, I guess I want the latest chipsets etc. I have Win7 x64 if that matters, and may go to Win8 when it's out.
Components
CPU - I'm sure an Ivybridge i5 would be fine, but which one?
In the past I've OC'ed a little, but I don't think it's a major requirement with current CPUs. Stability is more important to me than performance, and I think IO will be more important than raw CPU power.
RAM - Dual channel? Tri? Quad? Also not sure how much there is to choose between brands these days, if I'm not after extreme performance? Should 8GB be enough for now?
Mobo - Hopelessly out of touch here, I think an Ivybridge Z77 might be one way to go as it offers SRT (more on that later), but really need more advice.
Cooling - The quieter the better.
SSD/HDD - I have a new work laptop with an SSD, and love it, so SSD is a must.
But should I go for OS/Apps on an SSD and data on an HDD? Or a hybrid solution? Or an SSD/HDD combo with caching (and which is better, SRT or Dataplex)? I have a fairly new WD Caviar Black 640GB WD6402AAEX that I could re-use, but I'd be happy to buy a new HDD. My main archive storage is on a WHS, but it's old and a bit sluggish, so I need a decent amount of space on the PC for current files (including media).
Case - Needs to be quiet and no bright lights. Other than that, something that's easy to work inside.
PSU - Again, the quieter the better.
Graphics - I can't see myself needing SLI or Crossfire, just something with decent gaming potential that can handle an MMO or RPG. Could even go for something basic and add a gaming card later if needed to keep the initial cost down.
Audio - I'm assuming integrated sound is likely to be okay for occasional gaming?
Optical Drive - Don't need Blu-Ray, but it does need to be good at ripping CDs. Any thoughts?
Budget
I don't want to spend more than I have to, but I'm hoping I can get something decent for between £400-£600.
So...
What have I missed?
What would you recommend?
And thanks for reading this far!
Requirements
Components
In the past I've OC'ed a little, but I don't think it's a major requirement with current CPUs. Stability is more important to me than performance, and I think IO will be more important than raw CPU power.RAM - Dual channel? Tri? Quad? Also not sure how much there is to choose between brands these days, if I'm not after extreme performance? Should 8GB be enough for now?
But should I go for OS/Apps on an SSD and data on an HDD? Or a hybrid solution? Or an SSD/HDD combo with caching (and which is better, SRT or Dataplex)? I have a fairly new WD Caviar Black 640GB WD6402AAEX that I could re-use, but I'd be happy to buy a new HDD. My main archive storage is on a WHS, but it's old and a bit sluggish, so I need a decent amount of space on the PC for current files (including media).Case - Needs to be quiet and no bright lights. Other than that, something that's easy to work inside.
Budget
So...
What have I missed?
