Hi everyone
I've been using Macs for over 20 years (due to education and career) and have never ventured into the world of PCs.
However the time has come to upgrade my 2008 Mac Pro (2x 2.8 Quad Core Xeon) and with the lack of new models from Apple I'm contemplating moving to a PC. I work in Motion Graphics so the packages I use are After Effects (with Trapcode Particle effects) and Premiere.
So firstly - how easily do you think it'd be to get up and running with a PC? What I mean are things like software updates, compatibility etc? For instance on a Mac I get notifications to tell me that software updates are available for my hardware as well as software. Does the same happen on PCs or are there more glitches as there's a greater scope of mixing and matching?
I'll use this machine for work so a stable system is the upmost priority.
Secondly - Would it be possible for someone to give me some pointers in terms of speccing up a system. My only requirements would be that it be an upgrade from my existing system with 24GB RAM minimum (as After Effects uses every single drop of RAM) as well as CUDA based graphics cards like a Quadro.
Many thanks in advance
I didn't know that you could dual-boot them easily - not a Mac user.
Comparing it to the 20 minutes of the promax one with its 16 cores, i think my pc probably is doing the pc equivelant of smugface at the moment
