So front tyres on the CLK are quite low, it has Pirelli P6000's all round, not a tyre I rate, but the rears are almost new, even though the fronts are well worn.
Tyre size is 205/55 R16 91W
Been quoted £84 fitted for Conti PC2's which are great by my reckoning, so gonna fit them on the rear with the almost new P6000's on the front, hopefully making the car more prone to under rather than oversteer in an emergency.
My other option is to fit 4 PC2's and stick one of the good P6000's on the emergency wheel. (it has a worn P6000 on it already).
Would mean the Final P6000 would likely go unused and sit in my garage forever, but thinking that would be the best option, which way would you guys lean?
