- 27 Dec 2002
- Higham,kent.
That`ll just be the apn needing to be set for your network.
Once you have the official chinese ics update,extract it and place the dload folder containing update.app on the root of your sd card. You can either go through the menus on the phone and sd card update,or power off/remove the battery/replace it/press both volume buttons down while powering on. Phone will extract/update to ics.![]()
All i did was pop the dload folder on my sd card and went through the sd card update on the phone,unsure why your not updating correctly.
And not a prob,sorry i couldn`t be more help.![]()
