Do a fourth day with core, mobility, cleans, DB push press, etc.
Honestly, if you try 3 days of HST you won't want a 4th
Your set up would work though... I guess try it and see how you go, but 3 days is certainly more than enough with HST.
That's not HST. If you change the fundamental core of something, then it becomes something else.
It's like saying you're going to be a window licker but you're not going to lick anything![]()
Yes, it won't work. Not with the routines you have suggested.Yes it is different but it would follow the same rep, set, weight, cycle, and structure of HST but work for my time frame of 4 days per week, on/on/off/on/on/off/off.
The principles of HST are still the same just working in to 4 days instead of 3, of you want me to rename it to Syla5 Specific Training then cool, do you have any thoughts on this?
I hate resetting as I like to get a good grip of the bar and hold onto it with the chalk =P I could stop for a second inbetween reps tho?
EDIT: I think I need to work on my head positioning more also.
I'm only guessing here but I'm thinking you haven't used HST before? I have and I've got a journal of it spanning a few years. Trust me this routine is brutal and will test the recovery powers of any level lifter. It's so easy to get the volume all wrong.... and I'm telling you with absolute certainty you've got the volume all wrong.
The Push/Pull will murder you trying to Squat and Deadlift 4x times a week. The other routine is so far from HST I don't know what it is. The idea is to hit every muscle group every 48 hours, so what's your thinking behind that routine?
It's not that you couldn't get a routine like that to work with the correct volume and diet but it wouldn't be HST anymore than it would be a 5x5.That bins off that then, quite simply happy to accept people's experiences, and there wasn't much experience to support the push/pull I had found.
From your experience I would assume that 2 days I'm a row and HST just won't work?
What's wrong with 3 days? Just do cardio and mobility on the 4th?
You don't need to let go of the bar. What I mean by resetting is putting the bar back on the floor, getting tight and lifting again.
