Because there will be a way to let air in surely. Otherwise there is no way the fuel pump could function. Try pumping 50L of water out of a fixed airtight box and see how far you get before the tank collapses or you can't pump anymore.
Also had a reefer pack up with the same issue ( I was the wise one this time !!)
How long can a reefer run for on it's tank? How many litres is the tank on them?
How long they can run on it depends on the weather
True, Do you get freezer reefers and fridge reefers? (guess so)
Need to make a seperate thread, always loved the hidden tech in those, and a fair bit of $$$ in the maintenance/repair aspect, kinda fun work too!
