The Rapier Missile system has a maximum operating range of 8.2km. That means it doesn't even cover the borders of London.
Well at least your getting the range correct now, but I very much doubt they will only use one of them.
This will ultimately mean that should there be a threatening aircraft, it will be a lot closer than you think before they (the Rapier missiles) can shoot it down, and it will have a catastrophic effect.
As above, more than one.
It is also limited to line of sight. There must be a clear line between the rapier "base unit" and the target, and the missile throughout the entire flight of the missile for it to be used. You've been mistakenly believing the Rapier system is capable of long-range AA, also known as "beyond sight" AA.
No I have correctly been string the above, and that it does not need its target in visual range to target or shoot it.
I've pointed out to you a number of times that this is false, with facts to back it up - to which you've gone and had a quick Google, found something that looks like a counter argument (such as the "BlindFire" system) and posted in this thread without actually reading/understanding what it is you are posting.
Im going to say this one last time, I have never mentioned the rapiers "BlindFire" system, you brought that up. I spoke about its "blind fire" capability. blind fire is a term used to describe firing at something you cannot visually see (ideally via the use of radar or other tracking abilities). I had never heard of "BlindFire" when I made that comment.
You have been wrong, every time. Now you are trying to claim the topic of the discussion is not what it was to weasel out of it.
So your trying to say you weren't wrong you just misunderstood what the conversation was about? lol.
Edit:
You know I don't even care any more, way to trash out an interesting thread
/unsubscribe
