Some stupid Bitfenix Recon questions
18 Oct 2002
Kent
I just received my Recon fan controller and i have a few questions before i go ahead an install it.
Firstly, what are best locations to attach the temp sensors for CPU, gfx card etc?
Second, the controller has to USB connections - what are they for?
Finally, should I be using the Recon to control my Gelid Tranquillo as well or should i just leave that to the motherboard?
Thanks
[Edit] Whoopsie. I dont quite know how i managed to post this in this forum. Could a mod please move it to the appropriate forum? Thanks
Thanks
I'll answer the second question. Use the middle USB (not the one on the end)
I attached my cpu cooler to my controller it works perfectly if you attach the sensor to the heatpipe,
My probes are on
GFX
CPU
HDD
Intake air temp
Output air temp
