Man of Honour
- 8 Nov 2007
- Outer Space
All being well, I'll be ordering this card tomorrow
All being well, I'll be ordering this card tomorrow![]()
Is this another change??
Some food for thought.
My 7970 lightning has ASIC of 67.5%, max oc of 1207(not great for these, average about 1300 from what i have read) needs 1280mv for this.
Idle temps 32c, bf3 load 61
Heaven 1080 AA x 4, tess normal 2238,
So pretty similar.
Hoping for better under water.
Take anything you read about Afterburner 2.3.3 and what voltage you'll be able to use with truck load of salt, the guy writing Afterburner doesn't even have a card yet so has no way of programming voltage adjustment.
http://forums.guru3d.com/showpost.php?p=4355746&postcount=9
http://forums.guru3d.com/showpost.php?p=4357961&postcount=12
http://forums.guru3d.com/showpost.php?p=4360550&postcount=16
Looks like 2.3.3 could be pushed back to August if he doesn't get the card in time.
All ordered, be here tomorrow, yay![]()
I wonder if its gonna be a keeper???????
It better be, I've got nowhere to go if this doesn't work out! Fingers crossed eh!![]()
Not for now but couple of months, we might be hearing about its bigger brother!
I did say hearing and not getting, anyways nobody knows.by couple you mean 8-12 months
I am desperate to see one of these under water and the volts @ 1.3ish. I am curious to know if these were released almost at full potential or with headroom for MUCH higher clocks.
tbh I don't think the clocks will be much higher. My standard volts ocs are lower than a few reference. I'm hoping (probably in vain) that that is because the card is designed with more voltage in mind, LOL.
If I can't get full cover blocks though I'm gonna be a sad puppy.
(I am a NVIDIA fan)
That's the way it is with the 600 series, you're setting a frequency offset.
For example, +65 = it will boost by 65 more mhz
yes mate. afaik it's because of the dynamic nature of gpu boost, you can't set a forced frequency, so you use an offset.
