From the GPU to the HDD bay it's 26-27CM, so low profile RAM will not fit? Should I go for this?Not if its low profile. What dimensions are the inside of the case?
http://www.overclockers.co.uk/showproduct.php?prodid=MY-300-CS&groupid=701&catid=8&subcat=1517
The PC case picture I showed you is my old PC, the parts I'm going to buy is above which will go into my old PC case
