The New Cases Gallery
Watercooled pc.. Ocd wiring.. by http://www.samcatchesides.com/, on Flickr
Not finished on the wiring yet (not neat enough), and the lighting is the next project... Full custom diy RGB led system... :D
The res mounting is temporary until its been redrained and refilled.. Tie wrap isnt really a great permanent solution.
And the Dynamat thats visible will be trimmed and removed so its not visible on the back of the other case half (even though you cant see it when the case is together) ...
i7 2600k
ati 6990
ASrock extreme 4 gen 3 mobo
16gb corsair dominator
200mm rad in front with push/pull 200mm fans
120mm rad in back with push/pull 120mm fans
200mm fan in roof
Lots of carbon bits, and lots of time spent hiding wires...
Full photoshoot soon, when I can be bothered to pop it into the studio.
Sam
Awesome... I was thinking of a Corsair 600T but decided against it because apart from the roof theres nowhere to fit another 240mm rad but with the 200 and the 120 rads you have there you've given me ideas...
Can I ask what make are the 200mm white fans? They're gorgeous
Been on the forums awhile and never posted up my rig so here it is now that its respectable and a lot better looking that it used to be.
Thanks for looking. :)
Computer specs,
2500k 4.3ghz OC
7970 DCII 1150/1650 OC
16GB G.Skill ripjaw X ram
OCZ vertex 3 60GB SSD and 2 1.5TB samsung eco drives in raid 0 for storage.
the current case with the old graphics card in
quick shot of memory and the H80 block
arty shot of the front
New graphics card
Monitor and desk, really need to sort out a new desk so i can get everything onto it and find one big enough to cram into my room and still get 3 monitors on so I can eyefinity which i plan to setup in the near future.
and my nifty new purchase my webcam and my little computer helpers XD.
installed the new Corsairs today - GREAT GREAT fans, well made, heavy, and very quiet (140mm is a bit noisier though)
the 120mm SP120s are as good as SILENT though :)
so 2x120mm SP120 Quiets (1400rpm)
1x140mm AF120 Quiet (1150rpm)
