What options are there for a cheap machine to run XBMC. It doesn't need lots of storage or an optical drive, it will just be for streaming movies and videos to my HDTV, so the smaller and lower power consumption the better. It must, however, be very simple to setup. I don't have the skills or patient to start messing around in Linux to get WiFi and Audio drivers to work, so something that is the most plug and play possible would be best. It needs to do 1080p properly (I've heard murmurs of some 24p issues?) and 5.1 audio at least, preferably through the HDMI port.
In predicted ascending order of expense, I think my options are:
An Android Mini PC and wait for XBMC to be released for it
A Linux Mini PC and install either OpenELEC or XMBCbuntu
A pre built Media device that comes with an XBMC Linux build in it
A Windows (7) Mini PC with XBMC installed instead of WMC
The Windows device would be the easiest to setup, but its massively overkill and going to cost way more than the Linux options.
Ideally I would like either a cheap prebuilt box, or a combination of hardware I can build myself that is supported out of the box by OpenELEC or XBMCbuntu. An Android PC sounds OK, but I think controlling it with a remote will be a bit of a pain. Any suggestions?
