Jake will the s3 fit in that with a case?
I thought the S2 was a large handset, then took a look at the S3.
Too big for me. I thik the S2 is bang on for size, if your afer a big, yet still portable phone.
It's true that it's possible but why would you? It's plenty fast enough anyway. Some guys have under-clocked them to improve battery life, but I think that's more 'because I can' really.i got the S3 awesome phone love it anywayn i heard its possible to overclock a galaxy s3, is it true? is it worth it? does anybody care? lol
What kind of idle battery drain are people getting?
I seem to be losing about 1% per hour overnight, and I'm sure it was less than that before (but I can't remember exactly).
1% per hour overnight seems about right here.
1% sounds about what I had though I put mine into airplane mode over night now which gives about 1 % in 7 hours
Hi
Really want an S3 but slightly put off by reports of the signal problems with them, i.e dropped calls, compared to other handsets. I'm currently with Vodaphone.
How do people on here find signal strength?
Cheers
These are the type of things that were putting me off...
http://forum.vodafone.co.uk/t5/Samsung-Galaxy-S-III/samsung-galaxy-s3-signal/td-p/1146615
http://forum.xda-developers.com/showthread.php?t=1743594
http://forum.xda-developers.com/showthread.php?t=1699573
http://www.phonesreview.co.uk/2012/06/12/samsung-looking-to-avoid-galaxy-s3-antennagate/
Hi
Cheers
