***** The Official Galaxy Nexus Thread *****
Yeah, the same here. I've tried a different cable with it as well to make sure it wasn't that and it did the same thing. I guess its just a build defect, not a big one though like you say.
Just tried it with a cable at work, issue doesn't exist...wondering if its the cable itself...
Just did this and got the OTA update straight away
Steps I did :
1. Goto phone dial pad and type, *#*#2432546#*#* (checkin)
2. Goto apps - all apps - Google Framework Services-> clear data
3. Goto about phone - system updates - check
downloading now :)
Updated to Jellybean last night, have noticed every few minutes the phone seems to be searching for gps! Under location services I only have GPS satellites selected (as it was before the JB update). Unselecting this does stop the constant gps search, but I don't want to turn gps on and off each time I want to use googlemaps etc.
Is anyone else having this issue? Or know how to find out which app is requesting GPS?
Anyone having issues with their latitude widget. Doesn't seem to refresh the users or my location, however when you load the full app it works fine :S
This is only since upgrading to JB
So I updated to 4.1, and now Go SMS no longer vibrates with incoming messages. I've checked all the settings. Anyone found a fix?
