All I can be bothered saying ATM is that I'm staggered you've been here since 2009 and still don't know to fully star out your swear words!
I thinking of jumping on the Steedie manlove... err diet advice bandwagon everyone else seems to be on.
The one thing that I deffo let myself down with is my diet. Really need some kind consistancy.
Dieting, weight lifting is my exercising to lose weightWait...Calorie restricted? So are you on a cut or?
.Dieting, weight lifting is my exercising to lose weight.
Cheers bud,Well yes, cardio isn't necessarily needed I know that.
Your strength is going to be lower if in a calorie deficit, more than likely anyway. So lifts are bound to stagnate eventually![]()
Cheers bud,
I was unsure how much a deficit is likely to hinder progression - as I've yet to lift on a surplus (stupid diet!! <shakes fist>).
Urgh, is it just me who finds OHP progression really slow....
Been making steady gains on my squats/DP/DL but OHP/BBR are both falling behind.
Also, what's a respectable amount to squat?, as I'm on 90kg & have at least another 10 in me at my current level (but following the 5x5 progression slowly).
My BP is at 55kg, DL @ 110kg, Squat 90kg - but my BBR is only on 55kg & my OHP trailing behind at 40kg - are these ratios normal, or should I add some isolation on my lacking muscle groups to bring them closer together?.
Currently for additional exercises I'm doing
4X10 sets of press-ups,
2X5 16kg dumb-bell curls,
2X5 20kg dumb-bell rows
2x5 16kg dumb-bell shoulder press
5x5 40kg (a 20kg plate in each hand) calf raises
Followed by 5mins of HIIT then stretches (after my 5x5 routine).
I don't mind taking it slow, but I'd like to spend more time on muscle groups which are lacking.
I'm not sure if this calorie restricted diet is what's holding back progress or not, I guess I'll find out once I hit target & I eat for bulking instead of losing fat :/
or train strength on a maintenance level diet.Thanks for the tips,Your Ratio's seem pretty reasonable to be honest.
I followed stronglifts before and if you check out any forum that has a stronglifts thread etc you will see that OHP is the first lift that you will plateau on. Keep following the stronglifts format, once you stall 3 times on the exercise on 3 different training days in a row then deload 10% and go back at it from there.
Being on a cut wont hinder your strength as such, but it will limit muscle growth, so as has been said you will reach a limit where your body just doesnt have the resource to restore/build up new muscle.
I have found on both my cuts in the last year i have been able to pull new RM's my lifts, but i have made no progress after this, and as i get further in to the cut things really slow down.
Not sure what your goals are or what you look like, but i would suggest if you want to progress your lifts, switch to a bulking diet and hypertrohpy routine for a few months, then come back to a strength routine and refine that newly developed massor train strength on a maintenance level diet.
