- 30 May 2012
- Bristol
of course it wouldnt, you cant use them both together!
=D
Thanks for pointing that out, I knew I'd make a mistake somewhere
=D
Similar to my spec.
The mobo is a lil cheaper (i'd pay the extra for my mobo). You could use the OEM CPU to drop the cost further (like i did). This helps pay for a aftermarket heatsink so you can overclock. Or you could get the retail CPU and ditch the aftermarket heatsink for now to save cash.
The Z77 mobo not only allows overclocking of the intel K CPUs but lucidMVP uses the IGP to boost the GPU. The i3 would be fine for gaming but the Ivybridge i5K is a more powerful CPU and has a better IGP than the i3. The IGP (integrated graphics) is also used by quicksync to help with video encoding tasks by supporting software (both i3 and i5 have this but the latter is better)
Well, it would be less money spent, but the 3570k is a more powerful CPU compared to the 2120, especially when the 3570k is overclocked (which the 2120 cannot). In terms of whether it would make a difference in performance when gaming, it depends on the graphics card. If you were only using a 6850, there wouldn't be much difference, since it would be GPU bottlenecked either way (pretty sure a 2120 wouldn't bottleneck a 3570k in most games). However, if we are talking about using a GTX 680 on BF3 64 person multiplayer (which is quite stressful on the CPU), then the 2120 would definitely hold back the graphics card, whereas the 3570k would be fine. So in terms of forward thinking, the 3570k is more future proof in that you can upgrade the graphics card and get the full performance out of it (plus the 3570k supports PCI-e 3.0). But the 2120 is a good gaming CPU for the price.
hmm maybe i will get it for future reference....so dnt need to spent again and jus upgrade some parts....so according to that build how long will it last for me as in gamin perfmance wise..since new games comes with new requirements...also nned to see where i can cut down money xd
Yes sir, you did.oh god did i just read that?
ok i've played around, feel free to critique the build please, honosuseri
YOUR BASKET
1 x EVGA GeForce GTX 460 Superclocked FTW 1024MB GDDR5 PCI-Express Graphics Card (01G-P3-1363-KR) £124.99
1 x Intel Core i3-2120 3.30GHz (Sandybridge) Socket LGA1155 Processor - Retail £95.99
1 x SanDisk Ultra SSD 120GB 2.5" SATA II Solid State Hard Drive - (SDSSDH-120G-G25) £62.99
1 x Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) £52.99
1 x OCZ ZS Series 550W '80 Plus Bronze' Power Supply £49.99
1 x Gigabyte H61MA-D3V Intel H61 (Socket 1155) DDR3 Motherboard £47.99
1 x Xigmatek Asgard Pro Gaming Case - Black £34.99
1 x TeamGroup Elite 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz Dual Channel Kit (TED38192M1600HC11DC) £32.99
1 x OcUK Value 300Mbps NWP300E Wireless-N PCI Express Adapter £13.98
1 x OcUK 22x DVD±RW SATA ReWriter (Black) - OEM £12.98
Total : £544.88 (includes shipping : £12.50).
for 550 quid, on bf3, surprisingly (well maybe not so, since bf3 is usually nvidia favoured) the 460ftw is as good as a 6950! http://www.anandtech.com/bench/Product/510?vs=519
and managed to squeeze in a last gen 120gb sandisk ultra
but no z9, the asgard pro is a viable alternative though
but of course, the compromise is that the upgrade path of this rig is well...terrible ;p
Proper comparisonDo you need any peripherals? Or just a tower?
YOUR BASKET
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £179.99
1 x MSI HD 6850 "Dual Fan Edition" 1024MB GDDR5 PCI-Express Graphics Card £83.99
1 x Gigabyte Z77-DS3H Intel Z77 (Socket 1155) DDR3 Motherboard £75.98
1 x Alpenföhn Matterhorn Pure Edition CPU Cooler (Socket LGA2011/1366/1155/1156/775/ AMD AM3/AM3+/AM2/AM2+/FM1) £29.99
1 x Zalman Z9 Plus Tower Case with Fan Controller - Black £49.99
Bah, extension is messing about, total price: £577.87 inc shipping.
you can save yourself extra 10 pounds if you get b-grade items
YOUR BASKET
1 x Intel Core i5-3570K 3.40GHz (Ivybridge) Socket LGA1155 Processor (77W) - OEM £167.99
1 x **B Grade** MSI HD 6850 OC 1024MB GDDR5 PCI-Express Graphics Card £83.99
1 x **B Grade** Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (HD-252-SE) £40
1 x Thermalright True Spirit 120 CPU Cooler (Socket LGA775/1155/1156/AM2/AM3/FM1) £24.98
Total : £567.88 (includes shipping : £12.50).
if you can live without the z9 case, you can get it within budget
YOUR BASKET
Total : £552.88 (includes shipping : £12.50).
I dont see the point of buying a B-grade graphics card which is as expensive as one of the other brand new 6850's![]()
hmmm i love u..now i see less price xd..but grade b trsutable?
the b-grade one is overclocked
it was the 6859 that was on offer last week, might just have been a dsr, so nothing missing
I only suggested the i5 as the OP posted that he wanted to use fraps and do some video editing where the additional cores would be useful. Also the fact that it'll last as CPUs from several years ago (C2D & C2Q) still perform exceptionally for their age, so think of spending more now as a long term investment in your PC so you only need to upgrade your graphics in the future.. Oh Tamzzy and B-grade again![]()
