Uh-huh. Geo is the Greek word for "Earth".
http://en.wikipedia.org/wiki/Geothermal_heat_pump
A geothermal heat pump, ground source heat pump (GSHP), or ground heat pump[1] is a central heating and/or cooling system that pumps heat to or from the ground.
Not talking about using geothermal power, something completely different.
EK said:Thank you for contacting us.
The aforementioned blocks will be available in copper acetal and nickel acetal only.
The geometry and size of top is too complex, hence plexi tops are likely to crack putting us in akward situations afterwards.
How did this one slip me by??
7970 Lightning £369.95 on TWO!!!
Damn you OcUK, why do you do this a week after i've splooged nearly a grand on upgrades
Edit: Also the regular price has come down to £399.99, I can live with that![]()
cool, will see what to do... damn you Gibbo; getting the 670 FTWs now![]()
why the change ?
