I suppose I would be going for an all in one, as I assume they're much easier to install
I see you want a AIO solution. Meh, don't bother there liable to break and leak, just stick to a traditional HSF such this Arctic Cooling Freezer 7 Pro Rev 2, buy this week you can save 40p of the normal selling price. Such much better then the stock cooler. If you really want to get into water cooling I'm sure we can do a cheapish custom loop.
Yes, but an air cooler will often beat/equal it and be quieter.
Hi, don't forget air coolers just cool the cpu, most custom loop owners cool the cpu + gpu, all l hear is my WDHD500GB when being used.
As for my custom loop it cools my [email protected] + toxic6950@6970-950/1400MHz my pc room reached 26'c and after 4HRs gaming temps never went over core-temps never went 66'c, idle temps average 30>34'c/max across the cores 56>60'c using low rpm fans so its very quiet. I started with a H50 them built alow cost custom loop cooling cpu + gpu cost just under £300 then over 2yrs slowly upgraded my loop. All l do for a leak test is power up my PC check for leaks after 10 minutes idle then run prime for an hour them check it twice a day for afew days.
I wonder how many peeps on air coolers turned down their overclock due to the hot weather, me never.
Hi Cleeeco, AIO's > l was one of the first to get a H50 fom OCUK the stock fan was noisy and just couped with my [email protected]. But changed the fan to a Apache 120mm and that improved temps and was very quiet, l had it for nearly two years no-probs. They are agood seller and l agree a few will be unreliable as they have moving parts fan, pump + water leaks due to seals failing. Where a Prolimatech Megahalems only has fans, it would be interesting to see how many AIO's fail out of the AIO'S sold just from OCUK.![]()
And as the room heats up and the ambient increases so the overall temp of the PC components increases as well. Controlling ambient is critical to good cooling over long periods of time.
