Ah yeah I see it. Didn't think this through did you.I don't have any space now on the floor since the Fredrik has a barrier in the middle.
Have you tried to see how it looks on the top shelf, where the router is atm? That looks sturdy to me.
On a related note, get some new speakers manThose Dell units are over a decade old!
Sideways, on the top shelf.LOL! You're joking now aren't you?
I didn't had to think about anything when the desk costed me 5 quid and it's in excellent condition. Actually, I was planning to put the desk in another room for my old PC but then decided to just squeeze it into my room and put the case on top cos I like a desk a lot.
Excellent out of the box thinking. Yes, do what skully just said.
Tip: Do not remove the support bar at the bottom regardless of how annoying it is, it's seriously dependent on it to stop it from moving side to side. Just something i learned with mine![]()
Could you not just hoover your floor once in a while and save all this hassle?
I'd be more concerned about the small fire waiting to happen on the floor...
Having your PC up there does look rather odd. Regardless, in my experience the shelves can take a lot of weight.
Here's mine.
That's an all in one printer and an Onkyo AV receiver on the top shelf, which weight quite a few Kg together and the shelf doesn't bow at all.
I have another Fredrik with a load of music gear on it as well. I do love these desks but it's not as good as it's predecessor looks.
EDIT: Tip: Do not remove the support bar at the bottom regardless of how annoying it is, it's seriously dependent on it to stop it from moving side to side. Just something i learned with mine![]()
What desk is that mate and where did you get it from I am also looking for a desk ( not so bothered about price but shouldn't really cost too much ) I am currently looking at a metal desk with slide out keyboard and adjustable height but this would suit the dining room better. Also it's wide enough for my peripherals by the looks of it; I think the metal one will only just take my large size mousepad and microsoft sidewinder.
